[GRASS-dev] [GRASS GIS] #2935: r.watershed returns bogus flow direction without warning when using large "virtual" terrain
GRASS GIS trac at osgeo.org
Mon Mar 28 16:45:30 PDT 2016
"virtual" terrain
  Reporter:  mankoff      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.4
 Component:  Raster       |    Version:  7.0.3
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Changes (by mankoff):
 * cc: mankoff (added)
 * version:  6.4.4 => 7.0.3
Comment:
 I've upgrade to {{{grass 7.0.3}}} and this bug still exists. Here is an
 MWE to recreate it:
 grass70 -text ./nc_spm_08_grass7/PERMANENT
 r.rescale input=elev_srtm_30m output=HUGE_elev to=-30000,30000000
 r.rescale input=elev_srtm_30m output=OK_elev to=-30,30000
 r.watershed elevation=HUGE_elev accumulation=HUGE.acc drainage=HUGE.fdir
 r.watershed elevation=OK_elev accumulation=OK.acc drainage=OK.fdir
 g.gui.mapswipe first=HUGE.acc second=OK.acc
 g.gui.mapswipe first=HUGE.fdir second=OK.fdir
 Now that grass supports other planets
 https://grasswiki.osgeo.org/wiki/Planetary_mapping it is likely others
 will run into similar issues when flow routing over terrain with values
 significantly larger than Earth topography.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2935#comment:2>
