[GRASS-dev] [GRASS-SVN] r68061 - grass/trunk/lib/gis
Huidae Cho grass4u at gmail.com
Thu May 5 06:21:03 PDT 2016
Hi Martin,
This fix only affects the history, not its behavior. "v.info -h n" gives
you:
COMMAND: v.edit map="n" layer="1" type="point,line,boundary,centroid"
tool="delete" threshold=-1,0,0 where="" snap="no"
Without this fix, you'll see:
tool="delete" threshold=-1,0,0 snap="no"
and cannot reuse this command without manually adding where="".
BTW, I think v.edit n tool=delete where="" should delete all features
because you're selecting all records by "select * from n" without any where
conditions. So your results look OK.
Huidae
On Sun, May 1, 2016 at 4:51 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2016-03-15 9:56 GMT+01:00  <svn_grass at osgeo.org>:
> > Author: hcho
> > Date: 2016-03-15 01:56:28 -0700 (Tue, 15 Mar 2016)
> > New Revision: 68061
> > Modified:
> >    grass/trunk/lib/gis/parser.c
> > Log:
> > G_recreate_command: Add empty answers.
> > Fix the command history for e.g., v.edit where="". Without this fix,
> where="" is not included, which makes an invalid command.
> I tried to backport this commit to relbr70. My quick test:
> v.random out=n n=100 --o
> v.db.addtable n
> leads to the all features removed.
> Selecting features...
> 100 of 100 features selected from vector map <n at PERMANENT>
> 100 features deleted
> I thought that this should be fixed by this commit, right? So no
> features removed (?)
> Thanks for explanation. Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160505/2375e82b/attachment.html>
