[GRASS-dev] [GRASS GIS] #3012: g.region -p reporting correct projection, but unknown datum NAD83(2011) /North Carolina (USft)
GRASS GIS trac at osgeo.org
Fri May 6 09:03:25 PDT 2016
  Reporter:  dnewcomb     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.5
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Please try r68384 (datum string added to lib/gis/datum.table) and check if
 this is now correct:
 GRASS 7.1.svn (nc_data_test):~ > g.proj -w
 PROJCS["NAD83(2011) / North Carolina (ftUS)",
     GEOGCS["grs80",
         DATUM["NAD83_National_Spatial_Reference_System_2011",
 SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",36.16666666666666],
     PARAMETER["standard_parallel_2",34.33333333333334],
     PARAMETER["latitude_of_origin",33.75],
     PARAMETER["central_meridian",-79],
     PARAMETER["false_easting",2000000],
     PARAMETER["false_northing",0],
     UNIT["Foot_US",0.3048006096012192]]
 GRASS 7.1.svn (nc_data_test):~ > g.region -p
 projection: 99 (NAD83(2011) / North Carolina (ftUS))
 zone:       0
 datum:      nad83_2011
 ellipsoid:  grs80
 north:      1
 south:      0
 west:       0
 east:       1
 nsres:      1
 ewres:      1
 rows:       1
 cols:       1
 cells:      1
 If yes: backport candidate.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3012#comment:1>
