[GRASS-dev] [GRASS GIS] #3016: Add option to set scalebar length
trac at osgeo.org
Fri May 6 13:58:42 PDT 2016
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.3.0
Component: Display | Version: unspecified
Resolution: | Keywords: d.barscale, gsoc2016, cartography
CPU: Unspecified | Platform: All
Changes (by wenzeslaus):
* version: => unspecified
Comment:
I think the size should be specified in map units, for example user can
say `size=250` to get 250m scale bar. This seems like a simple and
actually a desired option. What are the units there probably depend on the
rest of the implementation or interface of d.barscale. With the current
implementation it would be probably meters by default but it should be
feet when the `-f` is used.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3016#comment:1>
