[GRASS-dev] [GRASS GIS] #2997: python editor refuses to run script with UI after closing GUI dialog
GRASS GIS trac at osgeo.org
Sat May 7 11:52:47 PDT 2016
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.2.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:  fixed        |   Keywords:  python, editor
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by wenzeslaus):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"68396" 68396]:
 #!CommitTicketReference repository="" revision="68396"
 pyedit: do not use onDone because it is not executed when GUI is invoked
 (fixes #2997)
 Now you can run again even if it is already running
 which is the same behavior as for normal module calls.
 It also uses the same temporary file once it was created
 to avoid the need to delete it all the time. It is deleted
 when file is actually saved.
 Also remove suppression of the GUI interface because we
 actually want to get GUI (the parameter does not work, r68395).
Ticket URL: </ticket/2997#comment:4>
