[GRASS-dev] Fwd: [OSGeo-Discuss] [trac service] inter-trac links enabled
Markus Neteler
neteler at osgeo.org
Sun May 8 11:21:34 PDT 2016
FYI!
---------- Forwarded message ----------
Date: Sun, May 8, 2016 at 6:09 PM
Subject: [OSGeo-Discuss] [trac service] inter-trac links enabled
To: discuss at lists.osgeo.org
Cc: sac at lists.osgeo.org
For those projects that are still using the OSGeo trac,
I've just enabled inter-trac links.
This means you can reference tickets/wikipages/changesets of
any OSGeo project using trac from any other trac instance by
simply prepending the project name in the link, like:
geos:changeset:2234
osgeo:#45
ubuntugis:wiki:WikiStart
The project name is the last portion of the trac entrypoint:
https://trac.osgeo.org/postgis <--- "postgis"
I hope you'll find it useful. Next step will be figuring out a
way to automatically show the incoming link from the target :)
--strk;
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
