[GRASS-dev] [GRASS GIS] #2865: Error when installing r.modis add-on and warning when starting grass
GRASS GIS trac at osgeo.org
Thu May 12 14:53:23 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.0.5
 Component:  Addons      |    Version:  svn-trunk
Resolution:              |   Keywords:  r.modis
       CPU:  x86-64      |   Platform:  Linux
Comment (by veroandreo):
 I tried removing all extensions, then removing {{{~./grass7/addons}}} as
 in #2968 and {{{g.extension r.modis}}} still yields the same error as
 originally reported.
 Fetching <r.modis> from GRASS GIS Addons repository (be patient)...
 Compiling...
   File "/tmp/grass7-veroandreo-17563/tmpvAd7vx/r.modis/scrip
 ts/r.modis.download", line 94, in <module>
     from rmodislib import product
 ImportError: No module named rmodislib
 make[1]: *** [r.modis.download.tmp.html] Error 1
 ts/r.modis.import", line 100, in <module>
     from rmodislib import resampling, product, projection,
 get_proj
 make[1]: *** [r.modis.import.tmp.html] Error 1
 Installing...
 /usr/bin/install: cannot stat ‘/tmp/grass7-veroandreo-1756
 3/tmpvAd7vx/r.modis/docs/html/r.modis.download.html’: No
 such file or directory
 make[1]: *** [install] Error 1
 3/tmpvAd7vx/r.modis/docs/html/r.modis.import.html’: No
 Updating addons metadata file...
 Installation of <r.modis> successfully finished
 At {{{~.grass7/addons/docs/html/}}} there's only r.modis.html and not
 r.modis.import.html nor r.modis.download.html, if that's of any help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:11>
