[GRASS-dev] [GRASS GIS] #2058: Example instructions in (grass/trunk) d.graphs' manual refer to d.frame
trac at osgeo.org
Fri May 13 18:42:22 PDT 2016
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.5
Component: Display | Version: unspecified
Resolution: fixed | Keywords: d.graph, d.frame
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
G7:d.frame is now present and is included in the doc of (except for
d.graph only in comments for creating example image):
* G7:d.graph
* G7:r.random.cells
* G7:r.surf.fractal
* G7:r.rgb
* G7:v.cluster (https://grass.osgeo.org/grass71/manuals/v.cluster.html)
Obtained by:
grep --exclude-dir={.svn,OBJ.*,locale,dist.*} -IrnE "d\.frame" */*/*.html
| grep -v "href=.d\.frame" | grep -v "d\.frame\.html"
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2058#comment:3>
