[GRASS-dev] [GRASS GIS] #3000: i.gensig overwrites signature file without warning
trac at osgeo.org
Sun May 15 05:50:44 PDT 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.0
Component: Imagery | Version: svn-trunk
Resolution: fixed | Keywords: i.gensig
CPU: Unspecified | Platform: Unspecified
Comment (by marisn):
Sorry, that change is wrong as it will check for file presence only if
OVERWRITE is set and fail to do so if it is unset (usual case). I reverted
it in r68432
I implemented a new function to find signature files in r68433 to not
change I_find_subgroup_file function within 7.x lifetime. Good question if
all hardcoded directory separators in lib/imagery should not be replaced
with HOST_DIRSEP as it is done in r68433 to match how G_file_name works.
Needs testing on Windows.
As of r68434 all (I hope) signatures generating modules perform check to
not overwrite signature file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3000#comment:4>
