[GRASS-dev] some question about GRASS vectors
Luca Delucchi
lucadeluge at gmail.com
Wed May 18 07:37:51 PDT 2016
Hi devs,
I'm working on a QGIS plugin to check the differences between an input
shapefile and the resulting GRASS vector. I have some doubts:
- a line with only a point is a valid line? I was thinking it should
not be valid but GRASS doesn't return any error
- is it correct that attributes for multipolygon or polygon with self
intersection (so GRASS creates two different areas) are not imported?
I attach three different GeoJSON that I used for my tests
Thanks in advance
ciao
Luca
www.lucadelu.org
Type: application/json
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160518/bc665e66/attachment.json>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160518/bc665e66/attachment-0001.json>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160518/bc665e66/attachment-0002.json>
