[GRASS-dev] [GRASS GIS] #3037: r.import - output name should not be required with -e flag
GRASS GIS trac at osgeo.org
Thu May 19 04:38:12 PDT 2016
 Reporter:  guano        |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:  7.0.5
Component:  wxGUI        |    Version:  7.0.3
 Keywords:  import       |        CPU:  Unspecified
 Platform:  All          |
 In r.import (import with reprojection), the -e flag should ignore if there
 is an output name defined, much like the 'remove mask' option.
 Also, the output name could be set to be the same as the input by default,
 like in r.in.gdal.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3037>
