[GRASS-dev] [GRASS-SVN] r68435 - grass/trunk/lib/proj
Maciej Sieczka
msieczka at sieczka.org
Fri May 20 00:18:58 PDT 2016
W dniu 15.05.2016 o 23:45, svn_grass at osgeo.org pisze:
> +TODO: It is recommended to rely on PROJ4's proj-nad package. For doing so,
> + there would be some changes needed to lib/proj/get_proj.c - the call
> + to pj_set_finder() should be removed so that PROJ looks in its default
> + locations for the files. Also changes needed to lib/proj/Makefile so
> + it no longer creates the /etc/proj and /etc/proj/nad directories within
> + a GRASS installation nor installs the files there.
Another option might be not to search for the grids in any particular
directory, but to rely on a user-provided full path to the grid file in
the PROJ_INFO.
cs2cs, gdalwarp etc. allow the "nadgrids" to be a full path to a grid file.
Maciek
