[GRASS-dev] Tests failing with "requires string, <type 'unicode'> provided"
Pietro
peter.zamb at gmail.com
Fri May 20 04:31:05 PDT 2016
On Fri, May 13, 2016 at 5:48 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> A lot of tests are failing:
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2016-05-02-07-00/report_for_nc_basic_spm_grass7_nc/testfiles.html
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2016-05-03-07-00/report_for_nc_basic_spm_grass7_nc/testfiles.html
> Seems like PyGRASS related marameter checking:
> The Parameter <where> require a string, <type 'unicode'> instead is provided
the commit: r68465, fix the tests:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2016-05-20-07-00/report_for_nc_basic_spm_grass7_nc/testfiles.html
All the best
Pietro
