[GRASS-dev] Tip: Compile addons with make MODULE_TOPDIR=/usr/lib/grass70
Vaclav Petras
wenzeslaus at gmail.com
Sat May 21 21:06:36 PDT 2016
On Sat, May 21, 2016 at 4:24 PM, <svn_grass at osgeo.org> wrote:
> Author: amuriy
> Date: 2016-05-21 13:24:32 -0700 (Sat, 21 May 2016)
> New Revision: 68480
> Added:
> grass-addons/grass7/vector/v.explode/
> grass-addons/grass7/vector/v.explode/Makefile
> grass-addons/grass7/vector/v.explode/v.explode.html
> grass-addons/grass7/vector/v.explode/v.explode.py
> Modified:
> grass-addons/grass7/vector/v.delaunay3d/Makefile
> Log:
> <v.explode> script added
> Modified: grass-addons/grass7/vector/v.delaunay3d/Makefile
> --- grass-addons/grass7/vector/v.delaunay3d/Makefile 2016-05-20
> 21:01:30 UTC (rev 68479)
> +++ grass-addons/grass7/vector/v.delaunay3d/Makefile 2016-05-21
> 20:24:32 UTC (rev 68480)
> @@ -1,4 +1,4 @@
> -MODULE_TOPDIR = ../..
> +MODULE_TOPDIR = /usr/lib/grass70
> PGM = v.delaunay3d
Hi Alexander,
just small tip which might be of interest to other contributors to Addons
as well.
There is no need to change the source code to achieve compilation of module
outside of GRASS source code. You can just run make like this:
and you avoid these things being committed (because you never need to add
them to the source code). Martin was so kind and already put that line
back. So now everything is fine.
Looking forward to more commits,
Vaclav
https://trac.osgeo.org/grass/changeset/68480
https://trac.osgeo.org/grass/changeset/68481
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160522/ec06ac67/attachment.html>
