[GRASS-dev] [GRASS GIS] #3045: OSX: command-C closes window instead of copying text
GRASS GIS trac at osgeo.org
Wed May 25 05:49:49 PDT 2016
 Reporter:  guano   |      Owner:  grass-dev@…
     Type:  defect  |     Status:  new
 Priority:  normal  |  Milestone:  7.0.5
Component:  wxGUI   |    Version:  7.0.4
 Keywords:  window  |        CPU:  x86-64
 Platform:  MacOSX  |
 On OSX, selecting a text in any command window and pressing Command-C will
 send a CLOSE WINDOW signal, instead of copying the text. Command-C should
 be used for COPY, as usual, while closing the window is done with
 command-W.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3045>
