[GRASS-dev] [GRASS GIS] #3046: Cannot set display font
trac at osgeo.org
Thu May 26 16:46:15 PDT 2016
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.5
Component: wxGUI | Version: 7.0.4
Resolution: | Keywords: display font
CPU: Unspecified | Platform: MacOSX
Comment (by cmbarton):
More information.
I removed the ~.grass7/wx file to force GRASS to rebuild it. This does
happen if save is pressed from preferences.
If I go to preferences and select either display or command console font,
I get a Mac-specific dialog to select fonts. But I cannot close the dialog
to save the font. I can only crash the GUI to get out of this. After that,
I was able to get the standard GRASS font dialog for display font and
select a standard font (Helvetica in this case). But that font is not used
in the display--only the old GRASS default font. I can even see
"Helvetica" in the wx file and it seems OK. But it is not recognized.
I have not been able to even get to the standard GRASS font selection for
the console font. Trying to select it only gives the 3 column Mac font
selector that does not work in this environment (which is why we had to
build the existing font dialog).
This is a pretty serious bug for the display. I don't know exactly when it
was introduced, but it is fairly recent since I've been making maps
periodically this year with no problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3046#comment:1>
