[GRASS-dev] [GRASS GIS] #3048: r.out.gdal does not write EPSG code of the projection
trac at osgeo.org
Fri May 27 15:45:48 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Keywords: r.out.gdal | CPU: Unspecified
Platform: All |
GeoTiffs produced with GRASS GIS 6.4, 7.0.4 and 7.1.svn do not contain the
AUTHORITY parameter for the projection, which is thus not properly
recognized by other tools (e.g. QGIS, but esp. GeoServer).
Related discussion on the GDAL mailinglist can be found here:
http://thread.gmane.org/gmane.comp.gis.gdal.devel/43019
g.proj -w gave the projection information as in the GeoTIFF, though
without any AUTHORITY parameters (as it is supposed to according to the
manual). The AUTHORITY tags seem to be added by r.out.gdal, except for the
authority parameter for the entire projection. Even if g.proj -g returns
epsg=25832.
Compared to GDALs GeoTIFFs also AXIS parameters are missing (see below).
GRASS 7.0.4svn (ETRS_32N):~ >g.proj -g
name=ETRS89 / UTM zone 32N
datum=etrs89
ellps=grs80
proj=utm
zone=32
towgs84=0,0,0,0,0,0,0
no_defs=defined
epsg=25832
unit=meter
units=meters
meters=1
GRASS 7.0.4svn (ETRS_32N):~ >r.out.gdal input=test output=$HOME/test.tif
GRASS 7.0.4svn (ETRS_32N):~ >gdalinfo $HOME/test.tif
Coordinate System is:
PROJCS["UTM Zone 32, Northern Hemisphere",
GEOGCS["grs80",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (0.000000000000000,1.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
GRASS 7.0.4svn (ETRS_32N):~ >gdal_translate -a_srs EPSG:25832
$HOME/test.tif $HOME/test2.tif
GRASS 7.0.4svn (ETRS_32N):~ >gdalinfo $HOME/test2.tif
PROJCS["ETRS89 / UTM zone 32N",
GEOGCS["ETRS89",
SPHEROID["GRS 1980",6378137,298.257222101,
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","25832"]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3048>
