[GRASS-dev] [GRASS GIS] #3043: Change default color table
trac at osgeo.org
Fri May 27 22:45:08 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: blocker | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.colors, d.rast, rainbow
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
`viridis` is now available in trunk (try `r.colors`). This color table was
developed for Matplotlib based on color properties and color perception
and then it won the community voting. See the attachments to see how it
behaves including gray scale print and simulated color blindness (I can
share also the full resolution images).
The number one unresolved thing from my point of view is that `viridis`
has 256 entries (most of the other color tables in GRASS has less than 20)
and some test should be done to see if there is some performance
difference. Also two pairs of colors are actually the same for the same
values. (These issues can be resolved any time later.) Finally, it seems
that on some screens `viridis` starts with more blueish color which
doesn't look that good while on some other with more violet color which
probably the right way (and looks better) but that's more a local issue.
Is anybody opposed to the change of default color table from `rainbow` to
`viridis` in GRASS GIS for release 7.2?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3043#comment:4>
