[GRASS-dev] [GRASS GIS] #1242: vector fills and line widths not displaying in latlon regions
trac at osgeo.org
Sat May 28 20:26:43 PDT 2016
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Display | Version: svn-trunk
Resolution: | Keywords: vector, display, d.vect,
CPU: | d.northarrow, cartography, gsoc2016
Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:20 annakrat]:
> In [changeset:"68531" 68531]:
> #!CommitTicketReference repository="" revision="68531"
> d.northarrow: fix multiplication of arrow in latlon regions, see #1242
and #1410
I removed D_setup (and left only D_setup_unity), which caused
D_is_lat_lon() return true and caused the call of ll_wrap_path. The
vertices had coordinates in pixels, not degrees, so ll_wrap_path computed
nonsense.
Please test, but it works for me.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1242#comment:21>
