[GRASS-dev] [GRASS GIS] #3017: support for background option for grid labels in d.grid
trac at osgeo.org
Mon May 30 08:25:12 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.3.0
Component: Display | Version: unspecified
Resolution: | Keywords: d.grid, gsoc2016, cartography
CPU: Unspecified | Platform: Unspecified
Comment (by lazaa):
Replying to [comment:2 annakrat]:
> Thanks for the patch, but I am getting weird results (see attachment).
It's possible I might have done something wrong when applying the patch,
because I needed to get rid of the whitespace changes. Could you please
check this?
> Also `bg_color` should be probably changed to `bgcolor` to be compatible
with all other modules having this option.
> Ideally please upload a new patch without the whitespace changes.
OK, I will change it to {{{bgcolor}}}. I think the problem is not in
whitespaces. The size of label background depends on the font size. I
tested it on several font sizes and I got good results but obviously it
doesn't work in general.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3017#comment:3>
