[GRASS-dev] [GRASS GIS] #3206: wxgui saving 3d display to file contains save as dialog
GRASS GIS trac at osgeo.org
Tue Nov 8 09:14:05 PST 2016
 Reporter:  marisn  |      Owner:  grass-dev@…
     Type:  defect  |     Status:  new
 Priority:  normal  |  Milestone:  7.2.1
Component:  wxGUI   |    Version:  svn-trunk
 Keywords:          |        CPU:  Unspecified
 Platform:  Linux   |
 When saving display to file from a 3D view, it grabs all window content
 area including any overlapping windows. In my case - the "Save As" dialog
 where output file name was chosen. The issue is that "Save As" dialog is
 not removed from rendering fast enough and thus wxgui map view window area
 still contains it. To reproduce the issue, one has to use slow enough
 system where updating screen area hasn't been finished before wxgui reads
 out its area contents for saving into a file.
 OpenGL vendor string: nouveau
 OpenGL renderer string: Gallium 0.4 on NV98
 OpenGL core profile version string: 3.3 (Core Profile) Mesa 13.0.0
 OpenGL core profile shading language version string: 3.30
 GRASS versija: 7.3.svn
 GRASS SVN revision: r69783M
 Build date: 2016-11-07
 Build platform: x86_64-pc-linux-gnu
 GDAL: 2.0.2
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.14.2
 Python: 2.7.12
 wxPython: 3.0.2.0
 Platform: Linux-4.8.4-gentoo-x86_64-Intel-R-_Core-TM-2_Duo_CPU_P9500_ at _2
 .53GHz-with-gentoo-2.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/3206>
