[GRASS-dev] [GRASS GIS] #3206: wxgui saving 3d display to file contains save as dialog
trac at osgeo.org
Tue Nov 8 09:21:11 PST 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Description changed by martinl:
Old description:
> When saving display to file from a 3D view, it grabs all window content
> area including any overlapping windows. In my case - the "Save As" dialog
> where output file name was chosen. The issue is that "Save As" dialog is
> not removed from rendering fast enough and thus wxgui map view window
> area still contains it. To reproduce the issue, one has to use slow
> enough system where updating screen area hasn't been finished before
> wxgui reads out its area contents for saving into a file.
> OpenGL vendor string: nouveau
> OpenGL renderer string: Gallium 0.4 on NV98
> OpenGL core profile version string: 3.3 (Core Profile) Mesa 13.0.0
> OpenGL core profile shading language version string: 3.30
> GRASS versija: 7.3.svn
> GRASS SVN revision: r69783M
> Build date: 2016-11-07
> Build platform: x86_64-pc-linux-gnu
> GDAL: 2.0.2
> PROJ.4: 4.9.2
> GEOS: 3.5.0
> SQLite: 3.14.2
> Python: 2.7.12
> wxPython: 3.0.2.0
> Platform: Linux-4.8.4-gentoo-x86_64-Intel-R-_Core-TM-2_Duo_CPU_P9500_ at _2
> .53GHz-with-gentoo-2.3
New description:
not removed from rendering fast enough and thus wxgui map view window area
still contains it. To reproduce the issue, one has to use slow enough
system where updating screen area hasn't been finished before wxgui reads
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.14.2
Python: 2.7.12
wxPython: 3.0.2.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3206#comment:1>
