[GRASS-dev] [GRASS GIS] #2918: Infinite loop in i.landsat.toar with method=DOS4
trac at osgeo.org
Wed Nov 9 01:37:31 PST 2016
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.6
Component: Imagery | Version: unspecified
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: All
Comment (by neteler):
(from offlist communication)
On Tue, Nov 8, 2016 at 1:43 PM, E. Jorge Tizado wrote:
> I prefer the first option: emit fatal-error like "DOS4 method isn't
> applicable for the scene because Because of not convergence of the
> method. Use other method or use other sun_elevation parameter." and
exit.
> I think that if it is not possible to use the DOS4 method, the user must
> know it and not generate an output different to the requested DOS4.
> Then, the user has to use consciously another atmospheric correction
method.
I have submitted the patch (slightly reworded) and backported it to 7.2
and 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2918#comment:6>
