[GRASS-dev] Passing computational region to individual commands
Vaclav Petras
wenzeslaus at gmail.com
Wed Nov 9 20:27:06 PST 2016
[was: Adding an expert mode to the parser]
On Sun, Sep 25, 2016 at 10:16 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Sun, Sep 25, 2016 at 5:40 PM, Sören Gebbert <
> soerengebbert at googlemail.com> wrote:
>> >r.mapclac --raster-region= --north= --south= --west= --east= --res=
>>> >--ewres= --nsres= --vect-region --raster-align= ...
> I like this in the sense that if the region setting for the module is
> something which should be managed by these extra options, then they should
> be managed in parser, rather than introduced one by one for individual
> modules.
> But how is this different from using GRASS_REGION? Convenience of --raster-region=?
> Better syntax than environmental variable?
It would work better when using GRASS GIS by grass command with --exec:
grass72 /path/to/grassdata/test1/PERMANENT/ --exec r.univar map=elevation
--region-raster=elevation
which needs to be now done using two commands:
grass72 /path/to/grassdata/test1/PERMANENT/ --exec g.region raster=elevation
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161109/03e120ce/attachment.html>
