[GRASS-dev] v.kriging: ERREUR :Interpolating values is currently under maintenance (optimization).,
Moritz Lennert
mlennert at club.worldonline.be
Thu Nov 10 08:26:46 PST 2016
Eva,
Trying to use v.kriging I now get:
"ERROR :Interpolating values is currently under maintenance (optimization).
Theoretical variogram of your data has been computed."
which you added in the code a few weeks ago.
Could you explain why ? Some students wanted to use v.kriging, but that
doesn't seem possible at the time.
It seems to me that v.kriging was working before that. If you are
currently working on the code, could you not simply work on a copy and
commit that once it's done, instead of creating a "maintenance mode" ?
Moritz
