[GRASS-dev] [GRASS GIS] #3010: PyGRASS fails to write vector map with attributes
trac at osgeo.org
Thu Nov 10 18:59:26 PST 2016
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 7.2.0
Component: PyGRASS | Version: svn-trunk
Resolution: | Keywords: vector, API break, backwards
CPU: | compatibility
Unspecified | Platform: All
Changes (by wenzeslaus):
* keywords: vector => vector, API break, backwards compatibility
* status: closed => reopened
* resolution: fixed =>
Comment:
The following from r68603 is breaking backwards compatibility between 7.0
and 7.2:
#!diff
- def write(self, geo_obj, attrs=None, set_cats=True):
+ def write(self, geo_obj, cat=None, attrs=None):
The old API should (must) be accommodated. If the old API is so bad, that
it needs to be replaced (rather than extended), then we should have one
transitional version where both APIs work and the old one gives a warning.
I don't have enough information to make the judgment.
Related to that, the error message does not give much information about
what is going on.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3010#comment:3>
