[GRASS-dev] [GRASS GIS] #3207: Create histogram of raster map fails
trac at osgeo.org
Fri Nov 11 01:52:38 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.2.1
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:8 martinl]:
> Replying to [comment:6 hellik]:
> > In my tests I'm using OSGeo4W-winGRASS,as I can see, you are using the
standalone, right?
> I cannot reproduce this issue even with osgeo4w installer. Could you
please test 7.2.0RC1 from experimental area? To know whether we need to
postpone RC2. Thanks.
see https://trac.osgeo.org/grass/ticket/3057#comment:18
standalone ''GRASS GIS 7.2.svn'' works without any problems; trying it
with the setup in #3057#comment:18 (standalone winGRASS pointing to the
OSGeo4W-python stuff), then I get the same error as reported above.
conclusion: the numpy startup issue (#3057) and this failing are
interconnected!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3207#comment:9>
