[GRASS-dev] [GRASS GIS] #3094: wxGUI: error when profiling a raster map
GRASS GIS trac at osgeo.org
Fri Nov 11 01:58:34 PST 2016
  Reporter:  hellik  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  reopened
  Priority:  normal  |  Milestone:  7.0.5
 Component:  wxGUI   |    Version:  svn-trunk
Resolution:          |   Keywords:
       CPU:  x86-64  |   Platform:  MSWindows 8
Comment (by hellik):
 Replying to [comment:3 hellik]:
 > Replying to [comment:1 martinl]:
 > > Should be fixed in 7.0.5svn.
 > now tested with
 > System Info
 > GRASS version: 7.0.5
 > GRASS SVN Revision: 69636
 > Build Date: 2016-10-02
 > Build Platform: x86_64-w64-mingw32
 > GDAL/OGR: 2.1.1
 > PROJ.4: 4.9.3
 > GEOS: 3.5.0
 > SQLite: 3.14.1
 > Python: 2.7.5
 > wxPython: 2.8.12.1
 > Platform: Windows-8-6.2.9200 (OSGeo4W)
 > Traceback (most recent call last):
 >   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\mapd
 > isp\frame.py", line 1044, in OnProfile
 > self.Profile(rasters=rasters)
 > isp\frame.py", line 1052, in Profile
 > controller=self.profileController)
 >   File "C:\OSGEO4~1\apps\grass\grass-7.0.5\gui\wxpython\wxpl
 > ot\profile.py", line 56, in __init__
 > BasePlotFrame.__init__(self, parent=parent, size=size,
 > **kwargs)
 > ot\base.py", line 92, in __init__
 > self.client = plot.PlotCanvas(self)
 > NameError
 > global name 'plot' is not defined
 > also in the 7.0.x-line still an issue.
 see ​https://trac.osgeo.org/grass/ticket/3057#comment:18
 standalone GRASS GIS 7.2.svn works without any problems; trying it with
 the setup in #3057#comment:18 (standalone winGRASS pointing to the
 OSGeo4W-python stuff), then I get the same error as reported above.
 conclusion: the numpy startup issue (#3057) and this failing are
 interconnected!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3094#comment:4>
