[GRASS-dev] [GRASS GIS] #3010: PyGRASS fails to write vector map with attributes
trac at osgeo.org
Fri Nov 11 05:18:10 PST 2016
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 7.2.0
Component: PyGRASS | Version: svn-trunk
Resolution: | Keywords: vector, API break, backwards
CPU: | compatibility
Unspecified | Platform: All
Comment (by wenzeslaus):
Replying to [comment:5 huhabla]:
> IMHO the former implementation was close to be a bug that was fixed in
trunk.
If it was buggy, than there should be a special `if` with an error message
(exception, fatal, assert) which will tell you that you are using old API
which was buggy and you need to change your code.
BTW, the current message is not that good even in context of the 7.2 API
only because you don't know what has the wrong type.
> For every new feature a new category was created by default, except a
category was already attached to the c_cat field in the geometry.
This does not seem buggy but as a simple one which not flexible enough for
advanced user but pretty good for new users.
> It was not obvious howto use the same category for different features.
This sounds like a problem with documentation or a need for additional
API, seems like a long jump to breaking backwards compatibility.
Don't take me wrong, I agree that the new API is needed. It just needs
some better handling for the 7.0 API. (We are getting complains about
breaking API for modules between 6.4 and 7.0, so I suppose users care
about backwards compatibility.)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3010#comment:7>
