[GRASS-dev] [GRASS GIS] #3137: d.redraw and d.mon
GRASS GIS trac at osgeo.org
Sun Nov 13 10:47:39 PST 2016
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Display      |    Version:  unspecified
Resolution:               |   Keywords:  d.redraw, d.mon, wx0
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 I think that this is related to the fact that when drawing a map, changing
 its data, then using d.vect or d.rast again with the same map name, no
 change is drawn.
 Probably the internal monitor history "tells" the user commands to not do
 anything since the map name is already therein (while the underlying data
 are meanwhile different). Just guessing...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3137#comment:1>
