[GRASS-dev] [GRASS GIS] #3156: Cannot export GRASS raster map using r.out.png (crashes on windows)
trac at osgeo.org
Sun Nov 13 13:15:30 PST 2016
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Raster | Version: 7.0.4
Resolution: | Keywords: r.out.png, wingrass
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:3 hellik]:
> Replying to [comment:2 neteler]:
> tested by
> System Info
> GRASS version: 7.2.svn
> GRASS SVN revision: r69794
> Build date: 2016-11-13
> Build platform: x86_64-w64-mingw32
> GDAL: 2.1.2
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.14.1
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200
DEBUG=3 on
r.out.png --verbose input=elevation at PERMANENT output=D:\dl\lz_10m\test.png
D1/3: G_set_program_name(): r.out.png
D2/3: G_file_name(): path =
D:\grassdata\nc_spm_08_grass7\user1
D3/3: G_str_to_color(): str = 'white'
D:\grassdata\nc_spm_08_grass7\user1\WIND
D2/3: file open: read (mode = r)
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228500
D3/3: region item: south: 215000
D3/3: region item: east: 645000
D3/3: region item: west: 630000
D3/3: region item: cols: 1500
D3/3: region item: rows: 1350
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: top: 1.000000000000000
D3/3: region item: bottom: 0.000000000000000
D3/3: region item: cols3: 1500
D3/3: region item: rows3: 1350
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D3/3: region item: t-b resol: 1
D1/3: rows = 1350, cols = 1500
D1/3: G_find_raster2(): name=elevation mapset=PERMANENT
D:\grassdata\nc_spm_08_grass7\PERMANENT\cell\elevation
D:\grassdata\nc_spm_08_grass7\PERMANENT\cellhd\elevation
D3/3: region item: format: -1
D3/3: region item: compressed: 1
D:\grassdata\nc_spm_08_grass7\PERMANENT\fcell\elevation
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\PE
RMANENT\cell_misc\elevation\f_format
RMANENT\cell_misc\elevation\gdal
D3/3: create window mapping (1500 columns)
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\us
er1\quant2/PERMANENT\elevation
RMANENT\cell_misc\elevation\f_quant
RMANENT\cell_misc\elevation\null
D1/3: G_find_raster(): name=MASK mapset=user1
D:\grassdata\nc_spm_08_grass7\user1\cell\MASK
Converting <elevation at PERMANENT>...
D1/3: G_find_raster2(): name=elevation at PERMANENT mapset=
D1/3: G_find_raster(): name=elevation at PERMANENT mapset=
er1\colr2/PERMANENT\elevation
D:\grassdata\nc_spm_08_grass7\PERMANENT\colr\elevation
D3/3: adding rule 55=55.58 0 191 191 75=75.73 0 255 0
D3/3: adding rule 75=75.73 0 255 0 95=95.88 255 255 0
D3/3: adding rule 95=95.88 255 255 0 116=116.03 255 127 0
D3/3: adding rule 116=116.03 255 127 0 136=136.18 191 127
63
D3/3: adding rule 136=136.18 191 127 63 156=156.33 20 20 20
Ticket URL: <https://trac.osgeo.org/grass/ticket/3156#comment:4>
