[GRASS-dev] [GRASS GIS] #2548: map display 3d view: error to display vector point
GRASS GIS trac at osgeo.org
Sun Nov 13 13:28:20 PST 2016
  Reporter:  hellik  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  major   |  Milestone:  7.0.6
 Component:  wxGUI   |    Version:  svn-trunk
Resolution:          |   Keywords:
       CPU:  x86-64  |   Platform:  MSWindows 7
Comment (by hellik):
 Replying to [comment:3 annakrat]:
 > So it seems Windows only problem.
 tested by
 System Info
 GRASS version: 7.2.svn
 GRASS SVN revision: r69794
 Build date: 2016-11-13
 Build platform: x86_64-w64-mingw32
 GDAL: 2.1.2
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.14.1
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200
 with the NC example mentioned above.
 Starting 3D view mode...
   File "C:\Program Files\GRASS GIS
 7.2.svn\gui\wxpython\nviz\tools.py", line 3247, in
 OnSetRaster
 self.UpdateSurfacePage(layer, data, updateName=False)
 7.2.svn\gui\wxpython\nviz\tools.py", line 5370, in
 UpdateSurfacePage
 self.OnSurfaceAxis(None)
 7.2.svn\gui\wxpython\nviz\tools.py", line 3784, in
 OnSurfaceAxis
 id = data['surface']['object']['id']
 KeyError
 'object'
 Loading raster map <elevation at PERMANENT>...
 Translating colors from raster map <elevation at PERMANENT>...
 Vector map <overpasses at PERMANENT> loaded (117 points)
 it's in the winGRASS7.0.x and winGRASS7.2.line.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2548#comment:7>
