[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
GRASS GIS trac at osgeo.org
Wed Nov 16 02:22:15 PST 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.texture
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:5 mmetz]:
 > Replying to [comment:4 mlennert]:
 > > Replying to [comment:3 mlennert]:
 > > > Just one question:
 > > > The manual says:
 > > > r.texture  assumes  grey levels ranging from 0 to 255 as input.  The
 input is automatically rescaled to 0 to 255 if the input map
 > > >        range is outside of this range.
 > > > But when I rescale the above (second) matrix to 0,255 I get a
 different result:
 > > > r.in.ascii --o in=- out=test_matrix <<EOF
 > > > north: 3
 > > > south: 0
 > > > east: 3
 > > > west: 0
 > > > rows: 3
 > > > cols: 3
 > > > 1 1 1
 > > > 3 0 0
 > > > 0 0 3
 > > > EOF
 > > > r.texture -s test_matrix out=text method=idm --o
 > > > r.stats -1n text_IDM_90
 > > > 0.40000007
 > > > r.rescale test_matrix out=test_matrix_rescaled to=0,255
 > > > r.texture -s test_matrix_rescaled out=text_rescaled method=idm --o
 > > > r.stats -1n text_rescaled_IDM_90
 > > > 0.16672371
 > > > I would have thought that the result should be the same ?
 > No, because the differences become larger, therefore IDM becomes
 smaller.
 According to Haralick et al. (1973), the gray tones are quantized which
 "guarantees that images which are monotonic transformations of each other
 produce the same results". Therefore IDM should indeed stay the same. That
 also means that the manually calculated result of 0.4 for the second test
 matrix is wrong and the correct result is indeed 0.48333332.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:6>
