[GRASS-dev] [GRASS GIS] #3210: r.texture: bug when non continuous series of values
trac at osgeo.org
Wed Nov 16 05:53:21 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.texture
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:7 mlennert]:
> Replying to [comment:6 mmetz]:
> > Replying to [comment:5 mmetz]:
> > > Replying to [comment:4 mlennert]:
> > > > Replying to [comment:3 mlennert]:
> > > > > Just one question:
> > > > > The manual says:
> > > > > r.texture assumes grey levels ranging from 0 to 255 as input.
The input is automatically rescaled to 0 to 255 if the input map
> > > > > range is outside of this range.
> > > > > But when I rescale the above (second) matrix to 0,255 I get a
different result:
> > > > > r.in.ascii --o in=- out=test_matrix <<EOF
> > > > > north: 3
> > > > > south: 0
> > > > > east: 3
> > > > > west: 0
> > > > > rows: 3
> > > > > cols: 3
> > > > > 1 1 1
> > > > > 3 0 0
> > > > > 0 0 3
> > > > > EOF
> > > > > r.texture -s test_matrix out=text method=idm --o
> > > > > r.stats -1n text_IDM_90
> > > > > 0.40000007
> > > > > r.rescale test_matrix out=test_matrix_rescaled to=0,255
> > > > > r.texture -s test_matrix_rescaled out=text_rescaled method=idm
--o
> > > > > r.stats -1n text_rescaled_IDM_90
> > > > > 0.16672371
> > > > > I would have thought that the result should be the same ?
> > > No, because the differences become larger, therefore IDM becomes
smaller.
> > According to Haralick et al. (1973), the gray tones are quantized
which "guarantees that images which are monotonic transformations of each
other produce the same results". Therefore IDM should indeed stay the
same. That also means that the manually calculated result of 0.4 for the
second test matrix is wrong and the correct result is indeed 0.48333332.
> Well, to be complete, the sentence says "Image normalization by equal-
probability quantizing guarantees..." And an algorithm to perform such
quantizing is given in the appendix. I don't think this algorithm is
implemented in r.texture.
Right. So it seems 0.4 is the correct result for the second test matrix.
This will be a somewhat larger patch.
Equal-probability quantizing could be done with r.quantile + r.recode.
According to literature and other resources, the number of gray levels
should not be too large, at least 16 but apparently less than 256. Maybe a
note in the manual would be helpful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3210#comment:8>
