[GRASS-dev] [GRASS GIS] #3211: Pygrass crash when trying to drop DB table
trac at osgeo.org
Wed Nov 16 13:23:28 PST 2016
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: PyGRASS | Version: svn-releasebranch72
Keywords: | CPU: x86-64
Platform: Linux |
When trying to drop an existing table, PyGRASS crash.
The table is created as follow:
l_junc = Link(layer=LAYER_JUNCTION, name=KWD_SECT_JUNCTION,
table=vect_map.name + TN_JUNCTION, key='cat')
t_junc = l_junc.table()
t_junc.create(COLS_JUNCTION)
When trying to drop the table or rewrite it:
if t_junc.exist():
t_junc.drop(force=True)
t_junc.create(COLS_JUNCTION, overwrite=True)
It gives the following error:
File "./v.in.swmm.py", line 196, in <module>
sys.exit(main())
File "./v.in.swmm.py", line 189, in main
write_vector(output_map, drainage_network)
File "./v.in.swmm.py", line 75, in write_vector
File "/usr/lib/grass72/etc/python/grass/pygrass/vector/table.py", line
1022, in drop
used = db_table_in_vector(self.name)
File "/usr/lib/grass72/etc/python/grass/script/db.py", line 192, in
db_table_in_vector
for f in vector_db(vect, stderr=nuldev).values():
File "/usr/lib/grass72/etc/python/grass/script/vector.py", line 49, in
vector_db
**args)
File "/usr/lib/grass72/etc/python/grass/script/core.py", line 461, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/usr/lib/grass72/etc/python/grass/script/core.py", line 329, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['v.db.connect', '--
q', '-g', 'map=drainage_network at kolkata', 'sep=;'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3211>
