[GRASS-dev] g.gui.tplot: AttributeError: 'module' object has no attribute 'EVT_COMBOBOX_CLOSEUP'
Veronica Andreo veroandreo at gmail.com
Wed Nov 16 14:24:52 PST 2016
Ciao Lu,
I've noticed that if I open g.gui.tplot from the GUI I can see the pointer
icon (arrow) to select a point in the map, however if I call g.gui.tplot
from the terminal, that pointer (arrow) is not there and the only option is
to copy/paste or type the coordinates. Is there a reason for that
behaviour? Is it on purpose?
Cheers,
Vero
2016-11-16 11:42 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> Hi Luca,
> opening and closing g.gui.tplot window with the upper-right [x] leads to
> g.gui.tplot
> Error in atexit._run_exitfuncs:
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
>     func(*targs, **kargs)
>   File "/home/mneteler/software/grass72/dist.x86_64-pc-linux-
> gnu/etc/python/grass/temporal/core.py",
> line 437, in stop_subprocesses
>     c_library_interface.stop()
> gnu/etc/python/grass/pygrass/rpc/base.py",
> line 176, in stop
>     self.client_conn.send([0, ])
> IOError: [Errno 9] Bad file descriptor
> Error in sys.exitfunc:
> line 176, in stop
> This is a Linux Mint box.
> Would be good to fix that for 7.2.
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161116/e3a2bd1a/attachment.html>
