[GRASS-dev] [GRASS GIS] #3100: v.vol.rst WARNING in GRASS 7 still says cellout and cellinp rasters
trac at osgeo.org
Fri Nov 18 00:17:43 PST 2016
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by mlennert):
Replying to [comment:4 neteler]:
> Attempt done in r69439: if ok to be backported
Actually, the test tests for the existance of both maps:
if ((cellinp != NULL) && (cellout != NULL)) {
so the message will pop up if either of them is missing or if both are
missing, so this is not very helpful. Especially when you don't give
either of them, you get:
ATTENTION: Unable to create <(null)> raster map without cross_input raster
map being specified
I think this should be handled by parameter dependency rules for the
parser, and not by the code. Something like:
G_option_collective(parm.cellinp, parm.cellout)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3100#comment:6>
