[GRASS-dev] changing %HOME% in winGRASS for a better R-winGRASS-integration - discussion
Anna Petrášová
kratochanna at gmail.com
Fri Nov 18 09:01:16 PST 2016
On Fri, Nov 18, 2016 at 11:29 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Anna Petrášová wrote
>> On Fri, Nov 18, 2016 at 9:14 AM, Helmut Kudrnovsky <
>> hellik@
>> > wrote:
>>> hi devs,
>>> the subject question oroginates from
>>> [GRASS-stats] GRASS can't find R packages from personal library on
>>> Windows
>>> https://lists.osgeo.org/pipermail/grass-stats/2016-November/001690.html
>>> technical background on winGRASS side:
>>> %HOME% is defined in winGRASS by:
>>> for trunk
>>> https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L712
>>> 712 def ensure_home():
>>> 713 """Set HOME if not set on MS Windows"""
>>> 714 if windows and not os.getenv('HOME'):
>>> 715 os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
>>> 716 os.getenv('HOMEPATH'))
>>> and for the 7.0.x-line
>>> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/lib/init/grass.py#L1338
>>> 1338 # set HOME
>>> 1339 if windows and not os.getenv('HOME'):
>>> 1340 os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
>>> 1341 os.getenv('HOMEPATH'))
>>> both definitions turn out to be (on the most newer windows boxes) the
>>> same
>>> as %USERPROFILE% (e.g C:\Users\yourusername).
>>> technical background on R side:
>>> if %HOME% is _unset_ on windows, R looks for private libraries in
>>> C:\Users\yourusername\Documents\R\win-library\3.3, etc)
>>> but if %HOME% is _set_ on windows, R looks for private libraries on the
>>> wrong place (C:\Users\yourusername\R\win-library\3.3, etc.) <= see the
>>> missing _Documents_ as opposite to above search path for private
>>> libraries;
>>> thus R can't expand its search path to private libraries, as these are
>>> installed by default in
>>> etc.
>>> some ways to overcome this R-winGRASS-integration issue:
>>> (1) add some notes in the GRASS-wiki to add manually R_LIBS_USER (=path
>>> to
>>> private library in R) via the windows control panel permanently or
>>> temporary
>>> in the winGRASS-command console by e.g. set
>>> R_LIBS_USER=path/to/your/private/
>>> (2) add some notes in the GRASS-wiki how to add R_LIBS_USER in a R
>>> session.
>>> (3) add some logic in the windows-winGRASS-bat-start up scripts to add
>>> R_LIBS_USER
>> Can we define R_LIBS_USER in R.bat?
>> https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/external/rbatch/R.bat
> R_LIBS_USER has to be set explicitely for a defined path to a private
> library of a defined version and so on; the question is what to set.
> better is to let R decide where to search for default.
>>> (4) add some logic in the (win)GRASS-startup-GUI to define R_LIBS_USER
>>> (5) or see [1] to set %HOME% in windows to %USERPROFILE/Documents instead
>>> of
>>> %USERPROFILE%
>>> add following line
>>> SET HOME=%USERPROFILE%\Documents
>>> below
>>> https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/env.bat#L23
>>> to catch the most common R private library installations.
>>> I couldn't find any hints in the source where %HOME% is used in winGRASS
>>> modules/scripts.
>> what happens if we don't set it in grass.py? I can't try now.
> tested in winGRASS7.0.5 by commenting out following line:
> # set HOME
> #if windows and not os.getenv('HOME'):
> # os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
> # os.getenv('HOMEPATH'))
> in C:\Program Files\GRASS GIS 7.0.5\etc\grass70.py
> the wxGUI starts, displaying raster and vector works, tested some modules,
> all worked.
> but no idea if there may be some more side effect; further no idea if there
> is probably more to do for the OSGeo4W-version.
> anyone more insight, if %HOME% is needed in winGRASS?
Done by Glynn in:
https://trac.osgeo.org/grass/changeset/37873
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/changing-HOME-in-winGRASS-for-a-better-R-winGRASS-integration-discussion-tp5296480p5296507.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
