[GRASS-dev] [GRASS GIS] #3213: v.net.iso - Segmentation fault
trac at osgeo.org
Tue Nov 29 05:40:51 PST 2016
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.0
Component: LibVector | Version: svn-releasebranch72
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by mmetz):
Replying to [comment:2 sebastic]:
> Replying to [comment:1 mmetz]:
> > For debugging purposes, is there any way to reproduce compilation of
the Debian package?
> Yes, download the source package and build in a Debian unstable chroot
with pdebuild. Or use the package git repository and the git-buildpackage
workflow documented in the Debian GIS Policy:
> https://pkg-grass.alioth.debian.org/policy/packaging.html#git-packaging
> Look at the debian/rules file for the configure options, and the build
log or dpkg-buildflags for the build flags (CFLAGS, LDFLAGS, etc).
Thanks. With Debian testing and GRASS 7.0.5, I could reproduce the
segfault with the standard grass package, a rebuilt package, and also
GRASS 7.0.5 compiled from source. Using the new tavl version from trunk
solved the problem. Backported to G72 and G70 in r69951,2.
This code has been working fine for the last 14 years, therefore I am not
sure if it is a bug in the code or a bug in Debian testing/unstable.
The ticket can be closed when new versions of G70 and G72 have been
packaged for Debian and are confirmed working.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3213#comment:3>
