[GRASS-dev] how to reproject a raster map with absolute numbers without losing data
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 30 10:35:43 PST 2016
Le 29 novembre 2016 22:33:39 GMT+01:00, Markus Metz <markus.metz.giswork at gmail.com> a écrit :
> For
>reprojection, something like r.in.xyz could work:
I'm currently going through this process and it raises a series of issues:
>1. convert raster cells to vector points with raster cell value as
>vector z
>value.
I use r.to.vect for this. The -b flag allows +/- fast conversion, but it takes into account all cells. It would be great to have a flag telling it to only convert non-null cells. Or at least a hint to set a mask, which seems to have the desired effect.
>2. reproject these vector points to the target location
I locally modified v.proj to add a 'Don't build topology' flag.
Is there any indication against this ?
>3. export the vector points with v.out.ascii format=point
>4. import the exported points with r.in.xyz method=sum
This works nicely.
Thanks ! If I find the time I will wrap this into a r.proj.aggregate (?) script...
>The method options of r.in.xyz could be added to r.proj for spatial
>aggregation, but that would mean that most of the code of r.in.xyz
>would
>need to be copied to r.proj, then adapted. That would be an interesting
>enhancement, also considering that gdalwarp offers as resampling
>methods
>near, bilinear, cubic, cubicspline, lanczos, average, mode, max, min,
>med,
>Q1, Q3.
But it doesn't offer sum....
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161130/3f0bf45d/attachment.html>
