[GRASS-dev] t.rast.mapcalc: The temporal map type of the sample dataset must be interval
Martin Landa
landa.martin at gmail.com
Wed Nov 30 14:08:14 PST 2016
2016-11-30 23:05 GMT+01:00 Veronica Andreo <veroandreo at gmail.com>:
> Maybe the method=equal, which is the default method for t.rast.mapcalc, is
> not defined for time instance data (?).
> Have you tried changing it? For example, setting method=start? Perhaps in
> that way, only start time is evaluated to perform the operation between time
> series.
thanks for tip, anyway changing method to 'start' doesn't seem to have
any effect, I am getting the same error. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
