[GRASS-dev] 7.0.5 release planning
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon Oct 3 09:55:19 PDT 2016
On 10/03/2016 06:47 PM, Markus Neteler wrote:
> https://grass.osgeo.org/news/63/15/GRASS-GIS-7-0-5-released/
> If there are no objections (i.e. winGRASS version are working etc.)
> then I will send out the announcement.
The UbuntuGIS link should be for ubuntugis-unstable instead of
-experimental, -experimental is used for testing purposes, most
UbuntuGIS users get their packages from -unstable like Ubuntu also syncs
its packages from Debian unstable.
Pre-releases like betas and release candidates are uploaded to the
experimental repository, after the final release is out and all
integration work is prepared, the packages are moved to unstable where
they should be in generally usable shape.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
