[GRASS-dev] [GRASS GIS] #2460: v.out.postgis doesn't export attribute table
trac at osgeo.org
Tue Oct 4 01:00:22 PDT 2016
Reporter: martin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: v.out.postgis
CPU: x86-64 | Platform: Linux
Comment (by martinl):
Replying to [comment:3 mlennert]:
> BTW, when I try
> v.out.postgis in=censusblk_swwake type=centroid
output='PG:dbname=nc_grass' --o
> I get
> ATTENTION: Unsupported geometry type (8)
> ATTENTION: Unable to write feature in vector map <censusblk_swwake>
> ERREUR :Feature type 8 is not supported
> Erreur de segmentation
Right, it's still issue and must be solved before closing this ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2460#comment:9>
