[GRASS-dev] Upcoming 7.2.0: review which addons to move to core
Sören Gebbert
soerengebbert at googlemail.com
Thu Oct 6 15:25:15 PDT 2016
2016-10-06 21:26 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> On Tue, Oct 4, 2016 at 11:02 PM, Sören Gebbert
> <soerengebbert at googlemail.com> wrote:
> > 2016-10-04 22:22 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> >> Recently I fixed bugs in r.stream.order, related to stream length
> >> calculations which are in turn used to determine stream orders. The
> >> gunittest did not pick up 1) the bugs, 2) the bug fixes.
> sorry for the confusion, r.stream.order does not have any testsuite,
> only v.stream.order has.
> >> I agree, for tests during development, not for gunittests.
> >> From the examples I read, gunittests expect a specific output. If the
> >> expected output (obtained with an assumed correct version of the
> >> module) is wrong, the gunittest is bogus. gunittests are ok to make
> >> sure the output does not change, but not ok to make sure the output is
> >> correct. Two random examples are r.stream.order and r.univar.
> > I don't understand your argument here or i have a principal problem in
> > understanding the test topic.
> > You have to implement a test that checks for correct output, this is the
> > meaning of a test.
> Exactly. During development, however, you need to run many more tests
> until you are confident that the output is correct. Then you submit
> the changes. My point is that modules need to be tested thoroughly
> during development (which is not always the case), and a testsuite to
> make sure that the output matches expectations is nice to have. In
> most cases,
Implement all tests while developing a module as gunittests and you will
have
a testsuite in the end. You have to implement the tests anyway, so why not
using gunittests from the beginning,
as part of the development process?
If you implement a Python library, then use doctests to document and check
functions and classes while
developing them. These doctests are part of the documentation and excellent
examples howto use
a specific function or class. And by pure magic, you will have a testsuite
in the end.
Have a look at PyGRASS, tons of doctests that are code examples and
validation tests
at the same time.
> <module_name> <args>
> if [ $? -ne 0 ] ; then
> echo "ERROR: Module <module_name> failed"
> exit 1
> fi
> should do the job
Nope.
> no offence :-;
> > You have to design a test scenario from which you know
> > what the correct solution is and then you test for the correct solution.
> > What is with r.univar? Create a test map with a specific number of cells
> > with specific values and test if r.univar is able to compute the correct
> > values that you have validated by hand.
> > -- what is the mean, min and max of 10 cells each with value 5? Its 5! --
> what is the correct standard deviation? sqrt((1/n) * SUM(x - mu)) or
> sqrt((1/(n - 1)) * SUM(x - mu))?
> If you decide to use the first version, then implement tests for the first
version.
If you decide to use the second version, then ... .
If you decide to support both versions, then implement tests for both
versions.
> r.univar uses sqrt((1/n) * SUM(x - mu)) but sqrt((1/(n - 1)) * SUM(x -
> mu)) might be more appropriate because you could argue that raster
> maps are always a sample. Apart from that, r.univar uses a one-pass
> method to calculate stddev which is debatable.
If you decide to implement a specific version of stddev, then write a test
for it.
Debating which version is more appropriate has nothing to do with the
actual software development process.
Best regards
Soeren
> Markus M
> > The most simple check for that is the raster range check in gunittest. If
> > you know what the range of the resulting raster map has to be, then you
> can
> > test for it. If this is not enough then you can check against the
> > uni-variate statistic output of the raster map, since you know for sure
> what
> > the result is for min, mean, median, max and so on. If this is not
> > sufficient use r.out.ascii and check against the correct solution that
> you
> > have created beforehand. If this is not sufficient then use pygrass and
> > investigate each raster cell of the resulting output map.
> > Best regards
> > Soeren
> >> Markus M
> >> > Best regards
> >> > Soeren
> >> >> my2c
> >> >> Markus M
> >> >> > Best
> >> >> > Sören
> >> >> >> One thing we could think about is activating the toolbox idea a
> bit
> >> >> >> more
> >> >> >> and creating a specific OBIA toolbox in addons.
> >> >> >>> Identified candidates could be added to core once they fulfill
> the
> >> >> >>> requirements above. Would that happen only in minor releases or
> >> >> >>> would
> >> >> >>> that also be possible in point releases?
> >> >> >> Adding modules to core is not an API change, so I don't see why
> they
> >> >> >> can't
> >> >> >> be added at any time. But then again, having a series of new
> modules
> >> >> >> can be
> >> >> >> sufficient to justify a new minor release ;-)
> >> >> >>> Or is that already too much formality and if someone wishes to
> see
> >> >> >>> an
> >> >> >>> addon in core that is simply discussed on ML?
> >> >> >> Generally, I would think that discussion on ML is the best way to
> >> >> >> handle
> >> >> >> this.
> >> >> >> Moritz
> >> >> >> _______________________________________________
> >> >> >> grass-dev mailing list
> >> >> >> grass-dev at lists.osgeo.org
> >> >> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161007/7d58132d/attachment.html>
