[GRASS-dev] Specify color as #RRGGBB
Vaclav Petras
wenzeslaus at gmail.com
Thu Oct 6 16:58:58 PDT 2016
Dear all,
in r69683 I've added few lines to support colors hexadecimal numbers for
colors when prefixed by hash. That's the syntax often used in HTML (CSS)
and by other programs and formats.
Now instead of
d.vect map=hospitals color=80:170:255
you can do this:
d.vect map=hospitals color=#50AAFF
which is useful when you are copy pasting colors from somewhere (like the
gcolor2).
The limit is that it works only for the places where G_str_to_color() is
used. Most notably it doesn't work in r.colors' rules file.
This can help with writing scripts but be aware that # starts a comment in
Bash, so use quotes.
Please comment,
Vaclav
https://trac.osgeo.org/grass/changeset/69683
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161006/36613b3f/attachment.html>
