[GRASS-dev] [GRASS GIS] #3179: g.extension not installing addons behind proxy
trac at osgeo.org
Mon Oct 10 08:32:58 PDT 2016
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Addons | Version: unspecified
Keywords: g.extension, proxy, addons | CPU: Unspecified
Platform: Unspecified |
Related to https://lists.osgeo.org/pipermail/grass-
user/2016-October/075337.html
when i try to use g.extension behind a proxy, following the example from
the manual, it gives me the following error:
g.extension ext=i.segment.hierarchical proxy="http://xx.xxx.xxx.xx:xxxx"
File "/usr/local/grass-7.3.svn/scripts/g.extension", line 1730, in
<module>
sys.exit(main())
File "/usr/local/grass-7.3.svn/scripts/g.extension", line 1675, in main
for ptype, purl in (p.split('=') for p in
options['proxy'].split(',')):
ValueError: need more than 1 value to unpack
Using the form suggested by Pietro:
proxy="http=<value>,ftp=<value>"
proxy="http=http://xx.xxx.xxx.xx:xxxx"
gives:
Fetching <i.segment.hierarchical> from GRASS GIS Addons repository (be
patient)...
ERROR: Extension <i.segment.hierarchical> not found
which is exactly the same as if I don't indicate the proxy at all.
FWIW, I normally use urllib2 to handle the proxy. However I have some
difficulties to apply this simple method to the 1700+ rows code (handling
several different addons sources for several os's) of g.extension, but I'm
behind a proxy and I'm available to test if you have a patch.
Here's what I do in python:
import urllib2
import os
proxy = urllib2.ProxyHandler({'http':os.environ['HTTP_PROXY']})
opener = urllib2.build_opener(proxy)
urllib2.install_opener(opener)
urllib2.urlopen('http://www.google.com')
Thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179>
