[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
trac at osgeo.org
Wed Oct 19 11:48:03 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.vect.stats
CPU: x86-64 | Platform: Linux
Comment (by mlennert):
I think I found the issue.
When running with g.gisenv set=DEBUG=1, I get:
v.vect.stats -p points=gc type=centroid areas=grid_one_cat points_col=col
countcol=count statscol=sum method=sum
D1/1: 9 cats loaded from vector (including duplicates)
D1/1: 5 cats loaded from vector (unique)
There should be only 1 unique cat.
The attached patch seems to solve this for me, but it needs testing and
review.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:3>
