[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
trac at osgeo.org
Wed Oct 19 13:20:13 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.vect.stats
CPU: x86-64 | Platform: Linux
Comment (by veroandreo):
I applied the patch and tested.
- For my data (615 points, 3600 areas split in 325 categories), I got
Segmentation fault.
- For the data generated with the commands you just posted, the result
looks fine when running v.vect.stats with -p flag.
GRASS 7.3.svn (nc_spm_08_grass7):~ > v.vect.stats -p points=gc
type=centroid areas=grid_one_cat points_col=col countcol=count
statscol=sum method=sum
Selecting points for each area...
100%
area_cat|count|sum
1|9|18
However, if you remove that flag, to actually update the attribute table
(which for this case it is supposed to have only one category), I get:
GRASS 7.3.svn (nc_spm_08_grass7):~ > v.db.select grid_one_cat
cat|row|col|rown|coln|count|sum
1|3|1|C|A|9|18
2|3|2|C|B||
3|3|3|C|C||
4|2|1|B|A||
5|2|2|B|B||
6|2|3|B|C||
7|1|1|A|A||
8|1|2|A|B||
9|1|3|A|C||
Is there something wrong with v.db.select or with v.edit? I followed all
your steps. But even if I do {{{v.db.select grid_one_cat}}} before
v.vect.stats (and after the v.edit step), I get all the old categories:
1|3|1|C|A
2|3|2|C|B
3|3|3|C|C
4|2|1|B|A
5|2|2|B|B
6|2|3|B|C
7|1|1|A|A
8|1|2|A|B
9|1|3|A|C
I'm lost...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:4>
