[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts	and statistics
    trac at osgeo.org
    Wed Oct 19 14:40:58 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.0
 Component:  Vector      |    Version:  svn-trunk
Resolution:              |   Keywords:  v.vect.stats
       CPU:  x86-64      |   Platform:  Linux
Comment (by mlennert):
 Replying to [comment:5 mlennert]:
 > Replying to [comment:4 veroandreo]:
 > > I applied the patch and tested.
 > > - For my data (615 points, 3600 areas split in 325 categories), I got
 Segmentation fault.
 > Yes, i just noticed this for the original test data (test_areas,
 test_points) as well...
 I can get rid of the segfault, but results are still not good. I have the
 feeling the issue is more profound than what I initially thought, so it
 would be better if MarkusM had a look at it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:6>
