[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
GRASS GIS trac at osgeo.org
Mon Oct 24 09:17:36 PDT 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  reopened
  Priority:  critical    |  Milestone:  7.0.5
 Component:  Packaging   |    Version:  svn-releasebranch70
Resolution:              |   Keywords:  lasinfo, r.in.lidar, v.in.lidar,
                         |  r3.in.lidar, libLAS
       CPU:  x86-64      |   Platform:  Unspecified
Comment (by hellik):
 Replying to [comment:12 annakrat]:
 > Tested 32 and 64bit 7.0.5, 7.2, standalone and OSGeo4W and las tools and
 v/r.in.lidar are not working. Several people here reported the same, it
 worked for one colleague for some reason. How did it get broken again?
 tested here with
 System Info
 GRASS version: 7.3.svn
 GRASS SVN revision: r69714
 Build date: 2016-10-24
 Build platform: i386-w64-mingw32
 GDAL: 2.1.1
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.14.1
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
 and
 lasinfo (libLAS 1.7.0 with GeoTIFF 1.3.0 GDAL 1.8.1 LASzip 2.1.0)
 v.in.lidar fails with the data from the
 [https://grasswiki.osgeo.org/wiki/LIDAR#Import_LAS_as_vector_points wiki
 example].
 also lasinfo itself fails on this sample data set.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:13>
